Heat Pump Lines Freezing - HVAC - DIY Chatroom Home Improvement Forum
Old 05-09-2009, 10:05 PM   #1
Heat Pump Lines freezing
I turned on my AC and I can see ice in the outside unit and the lines that run all the way to air handler. What can be wrong. The fan on the air handler is running.
dec1000 is offline   Reply With Quote
Old 05-09-2009, 10:21 PM   #2
Electrical Contractor
kbsparky's Avatar
1) Low on freon.
2) Filter clogged
3) "A" coil clogged
Have the system checked.
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 04:05 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 11:28 AM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 03:11 PM
