Heat Pump Issue - HVAC - DIY Chatroom Home Improvement Forum
Old 07-01-2012, 02:40 PM   #1
heat pump issue
This morning my heat pump came on and the outside unit was running as well as the inside unit but the air coming out was not cold. So I turned the thermostat to off and waited for 15 minutes and put it on cool and it worked fine and I was wondering what would cause this. I wondered if I have a pending problem or could it have been a fluke?
peperry is offline   Reply With Quote
Old 07-01-2012, 02:46 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
it is possible that the compressor did no start outside and only the fan was running. This could indicate a compressor or capacitor problem.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 07-01-2012, 02:50 PM   #3
Should I set up an appointment with my home warrannty company or wait and see if it happens again? They replaced a start capasitor last year but the outside unit wouldn't come on at all.
Old 07-01-2012, 02:51 PM   #4
AKA HVACTECHFW
good luck with your home warranty! Doubtful they cover anything that isn't completely broken.
IT IS WHAT IT IS
Heat Pump Efficiency Help! horseonthefly HVAC 5 03-16-2012 04:14 PM
Heat Pump Crisis Part II Doc Holliday HVAC 58 12-07-2011 09:14 PM
Heat Pump Crisis, Help! Doc Holliday HVAC 14 12-02-2011 09:22 PM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 06:53 PM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 12:19 PM
