Heat Pump HEATER KIT As Shop Heat - Need Thermostat Wiring Help !! - HVAC - DIY Chatroom Home Improvement Forum
Old 11-01-2011, 08:35 AM   #1
I have a good heater kit with blower that I would like to use for heat in my shop(I have the necessary wiring/amps available, and yes, our electric is cheap). It is a model H3HK020H-01 from Nordyne...Ive attached a wiring diagram below.
I can wire the blower motor (not pictured) and the heat coils just fine to run directly, but I would like to add a thermostat to the control end. I was wondering what parts I need to do so and which of the colored wires I use.
I have the unit as basically diagrammed, out to the blocks where supply voltage comes in and then the colored wires to the plug.
Any assistance appreciated. I am wiring familiar, just not much so with HVAC type equipment. My normal skillset is wiring shop motors and doing residential electrical work.
Thanks,
Brad
703829a.pdf
bradsguns is offline   Reply With Quote
Tags
electric , heat , heat pump , shop heater
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
Goodman Heat Pump 2 Thermostat Wiring RanLoot Electrical 1 05-09-2010 07:20 AM
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 03:05 PM
programmable thermostat + heat pump Potomac101 HVAC 10 12-03-2008 10:02 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 09:10 PM
