Heat Pump Heat Strip Has Power When Hot Leads Are Disconnected? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-04-2011, 02:33 PM   #1
Heat pump heat strip has power when hot leads are disconnected?
I have a lemon of a heat pump. I didn't install it, but I don't have the funds to replace it either.
I've replaced four heat strips in the last six years. The last one has lasted less than one year. I went to look at it to verify that it was burnt through like it usually is. Put it back together and was ready to call the HVAC guy out, when I heard a buzzing noise that wasn't there earlier. I also noticed that one of heat heat strips was glowing.
Disconnected power again to take it back apart. Looked the same. Turned power back on and it still buzzed. Turned off power and disconnected the hot leads, thinking it was shorting out somewhere. Turned the power back on. STILL buzzing.
Any idea where this is being backfed from?
pigdog is offline   Reply With Quote
Old 12-04-2011, 02:44 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
a relay? you are going to have to be more specific in your description. Where did you disconnect the "hot leads" from? Can you post some pictures?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 12-04-2011, 03:11 PM   #3
I disconnected the hot wires going to the heat strip. I'll try and take some pictures later.
Old 12-05-2011, 05:18 AM   #4
Sounds like your contactor is either stuck in or getting a call to come in. This is probably why you are burning so many heating strips out.
twelvevoltman is offline   Reply With Quote
Old 12-05-2011, 05:51 AM   #5
jkv
Sequencer? Did you try that, did you unhook all wires to all three? This is a 15kw right
jkv is offline   Reply With Quote
Old 12-06-2011, 12:00 AM   #6
No, an 9.5kw. It's about 20 years old I guess. Affectionately known as "Frankenstein." Why "Frankensein?" It's been cobbled together so bad because parts are hard to find. Hopefully tomorrow, I'll have a chance to do some more digging into it.
New heat pump wiring question jmedenf HVAC 3 10-14-2011 07:26 PM
Heat Pump Thermostat HELP!!! MichaelG HVAC 22 12-09-2010 05:50 PM
New Install - Heat Pump Woes... mark1210 HVAC 7 03-07-2010 10:14 AM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 07:15 AM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 03:11 PM
