Heat Pump Heat Lost Calculations ??? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-24-2010, 10:50 PM   #1
Question
heat pump heat lost calculations ???
I did a heat loss calculation from HVAC computer systems, great program, one thing I am unclear of there are two large rooms in my house that were an addition and the previous owner never ran ducting to them ( use electric and on has a fireplace) would I include these rooms in my calculations???
mark2007 is offline   Reply With Quote
Old 05-25-2010, 09:09 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,130
Yep. If they have exposed walls heat will radiate thru them and will add load to the furnace/unit when the supplemental heat is Off. They also add to the cooling load. Do the calculation both ways and see how big a difference there is. You may want to get Pro to assess your ductwork size for a new furnace B4 replacing it if you have it for supplemental heat/dual fuel. Depending on your climate a smaller furnace may be okay. A 2 or 3 stage furnace may also help as it runs longer and uses less gas. Heat loss calcs are not gospel and an experienced tech can help determine the proper size.
The Following User Says Thank You to yuri For This Useful Post:
mark2007 (05-25-2010)
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 04:59 AM
Heat pump and Honeywell 8000 questions. jyoderz HVAC 14 04-06-2010 03:26 PM
New Install - Heat Pump Woes... mark1210 HVAC 7 03-07-2010 10:14 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 09:34 PM
Brand new Carrier Infinity 16 Heat Pump Stopped Working I think needmyac HVAC 3 07-07-2009 07:12 PM
