Heat Pump Going Into Defrost Mode In The Summer - HVAC - DIY Chatroom Home Improvement Forum
Old 09-01-2012, 08:46 PM   #1
Heat pump going into defrost mode in the summer
Recently I replaced the condenser motor and capacitor. Same day the unit started going into defrost mode about every hour and staying in that mode for 20 or 30 min. So I replaced the defrost board the abiant sensor and the sensor that goes up in the copper tube that check the temp to make sure it isn't freezing up. Also put in a new digital thermostat inside. After all of that still doing the same thing. I replaced the condenser motor because it wasn't running just humming and when I would try to force the start up it wouldn't Any suggestions would be great. Thanks
Dukeman456 is offline   Reply With Quote
Old 09-01-2012, 11:04 PM   #2
An old Tradesmen
Rewards Points: 6,468
Brand and model number would help.
Old 09-02-2012, 09:57 PM   #3
HVAC Tech/ Browns Fan
You made sure reversing valve is in ac mode not heat? What is the temp when u did this all? Check defrost switch for wire split and touching?
Tator1076 is offline   Reply With Quote
Heat Pump Defrost Problems khafner HVAC 1 12-13-2010 06:57 PM
Heat Pump Defrost Question zootjeff HVAC 12 11-23-2010 04:31 AM
Adjusting Heat Pump Defrost Cycle chip19474 HVAC 1 02-01-2010 10:10 AM
heat pump cut off set point oldswab HVAC 4 12-02-2009 03:09 PM
Water Source Heat Pump installation JLMitchell HVAC 6 11-30-2009 04:23 AM
