Heat Pump Fuse - HVAC - DIY Chatroom Home Improvement Forum
Old 05-31-2011, 09:23 PM   #1
Rewards Points: 33
Heat Pump Fuse
So it finally gets hots enough to want the AC on, and while the fan is blowing the place is not cooling lower than low 80's. I discovered the unit is not even running. It's a Bryant Legacy heat pump, installed less than 3 years ago. There's a little gray box outside next to it, with two lights saying "Line 1 (Line 2) fuse bad when lit." And the line 1 one is lit.
My first stupid question is whether this is like a car, where I can just buy a fuse and plug it in somewhere? I don't know to what fuse it refers. I can see a piece inside the box that either opens or comes out - it's a little black section at the top with a metal handle. The bottom gray portion has a screw.
I'd almost rather drag my old window a/c down from the attic than call these bozos I bought this thing from. Let's just say there's a bit of "history" with these people. I need to put a whole letter together to them but wish to wait until I can get everything together at once.
Is this like the kind of fuse that can just konk out after some time and be replaced... or does this mean something is wrong in the wiring? Even if I can replace it myself, I'd certainly like to know why it happened.
Erimess is offline   Reply With Quote
Old 05-31-2011, 10:14 PM   #2
An old Tradesmen
Rewards Points: 6,112
Generally, when a fuse blows, something caused it to blow. You can try putting another fuse in. But before you do, you need a multi meter to check out why it blew.
Using Gas heat during Defrost mgroves HVAC 15 12-18-2010 06:51 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 09:13 PM
New Install - Heat Pump Woes... mark1210 HVAC 7 03-07-2010 10:14 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 09:34 PM
What temp does my Heat Pump stop producing good heat or what is the threshold? twilightcall HVAC 15 02-12-2010 10:46 PM
