Heat Pump Frosting - HVAC - DIY Chatroom Home Improvement Forum
Old 01-02-2016, 08:03 AM   #1
Rewards Points: 461
Heat Pump frosting
Was outside this morning cleaning up and noticed that the heat pump outside has a little bit of frost on the coils. Is this something I should be concerned about? Is it not as effective when it does this?
The weather when I seen it frosted slightly was
Outside
22 degree windchill
24 degree dewpoint
83% humidity
Indoor temp
set at 73 degree
actual temp 73
Humidity 36%
cincinnati guy is offline   Reply With Quote
Old 01-02-2016, 08:13 AM   #2
Rewards Points: 3,832
Sounds like it was pretty cold in your area.
Frosting is normal. That's what the defrost control in the unit is for. Heavy ice/thick frost is not normal.
roughneck is offline   Reply With Quote
Old 01-02-2016, 11:58 AM   #3
An old Tradesmen
Rewards Points: 7,328
Windchill has little to no bearing on a heat pump. Except when its in defrost.
Without knowing the actual temp, can't tell much about whether it should have a lot of frost or not.
30F at a 15MPH wind is a windchill of 19F.
Old 01-02-2016, 03:33 PM   #4
Rewards Points: 7,678
should defrost itself every 60-90 minutes or so or on demand when there's too much. most are timed.
My Backround FIY: I am not in the business of any trade or topic I give advise on. I have some have formal education in HVAC + some DIY experience. Theory is not a substitute for experience.
user_12345a is online now   Reply With Quote
Lennox Heat Pump no_limit_larry HVAC 4 11-05-2012 05:18 PM
dual fuel heat pump - no heat without propane sweetfarm HVAC 3 10-11-2012 08:07 AM
Can I connect Honeywell Vision PRO 8000 (1 Heat/ 1 cool) to a Heat Pump w/aux for heat coils? TimDavis HVAC 12 01-18-2012 07:06 AM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 08:13 PM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
