Heat Pump Filter Dryer - HVAC - DIY Chatroom Home Improvement Forum
Old 05-15-2010, 10:48 AM   #1
I have A Heat Pump with a vapor line filter dryer on it, the filter dryer is a standard one way dryer, not a by-flow. my question is will this filter dryer work on a heat pump without causing a problem?
bobolink2000 is offline   Reply With Quote
Old 05-15-2010, 02:16 PM   #2
An old Tradesmen
Rewards Points: 7,786
Yes, and no.
In heat mode. The dirt will tend to be forced out of it. If its installed on the vapor line outside of the unit.
If its installed between teh reversing valve and compressor. no problem.
Old 05-15-2010, 02:49 PM   #3
I guess the best thing to do is replace this filter dryer, thanks for the help, beenthere
Old 05-15-2010, 02:58 PM   #4
An old Tradesmen
Cut it out, and repipe where it is. And then remove the old LLFD install a new LLFD.
The Following User Says Thank You to beenthere For This Useful Post:
bobolink2000 (05-15-2010)
Old 05-16-2010, 03:53 PM   #5
Thumbs up
Heat pump filter drier
THE BEST THING YOU SHOULD DO IS GET A BI-FLOW DRIER WHICH IS THE ONE THAT HEAT PUMPS SHOULD HAVE. YOU DON't WANT ANY MOISTURE OR DIRT GOING BACK TO YOUR COMPRESSOR.
Dennis Diaz is offline   Reply With Quote
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 06:53 PM
New Heat Pump..questions? ddave23 HVAC 4 03-05-2010 05:13 AM
Heat pump vs in floor heat mugen HVAC 5 03-02-2010 08:18 PM
Cheaper Sources for Heat Pump Filter duckdown HVAC 2 10-26-2009 06:10 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 11:49 AM
