Heat Pump Fan Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 10-14-2011, 04:31 PM   #1
Heat pump fan problem
The fan on the outside portion (condenser, coils, whatever you wanna call em) of my heat pump has quit working. (again) This happened about 2 months ago and they came in and replaced the fan motor and capacitor. When it went out that time, it would quit spinning and buzz loudly as the fan motor was trying to spin. A quick boost from a long screwdriver would get it spinning again for a little while. This time the buzzing sounds different and the push from the screwdriver starts it going, but it never actually gets up to speed and then stops 10-20 seconds later. My thought is that its something electrical this time, but I'm not sure where to start checking. Any help on trouble shooting would be appreciated.
jtitus07 is offline   Reply With Quote
Old 10-14-2011, 05:32 PM   #2
Check the capacitor. It and the motor should have a 1 year warranty if you don't want to mess with it.
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 05:28 PM
Heat Pump will not cut off sunliner HVAC 13 05-17-2011 06:38 AM
Trane Heat pump capacitor exploded! swiffy25 HVAC 18 01-19-2011 06:48 AM
heat pump question David from MD HVAC 3 02-01-2010 09:42 PM
Heat Pump set back GEAF HVAC 6 01-26-2009 08:49 AM
