Heat Pump Fan Motor? Last 5 Serial Number? - HVAC - DIY Chatroom Home Improvement Forum
Old 04-29-2009, 01:05 PM   #1
Question
Heat pump fan motor? last 5 serial number?
My heat pump has a 5kcp39fg "r560s" motor in it a 1/4 hp, volt 208/230, 1100 rpm motor to be exact. I found ver inexpensive a 5kcp39fg "m599s" motor for sale which has the same specs. Should I buy it or should I just buy oem and spend an extra $150? Will it work, will I have to find a capasitor for the new motor or does anyone have a suggestion of a motor and capasitor that would work for replacement?
andrewlewis is offline   Reply With Quote
Old 04-29-2009, 04:52 PM   #2
biggles's Avatar
what brand is the unit itself,and is it for the air handler or the condenser outside?
Old 04-29-2009, 08:10 PM   #3
It is a carrier heat pump and it is outside condensor
Tags
air conditioner , carrier , condenser , fan motor , heat pump
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 03:05 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 10:28 AM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 02:11 PM
