Heat Pump Fan Motor- Capacitor - HVAC - DIY Chatroom Home Improvement Forum
Old 07-20-2011, 12:55 PM   #1
Heat pump fan motor- capacitor
have a Lennox heat pump that had the fan motor replaced about three years ago. A month ago the fan stopped turning and was making a whining sound. Called repair person but fan had started working again. Repair guy said it was a bad capacitor and replaced it. Woke up this morning with same problem don't want to pay again for it to only work a month. Looking at wiring diagram it shows one dual capacitor but there were three single capacitors installed. Two wired together and one by itself going to fan motor. The one going to fan motor is the one replaced last month. Have gone out and purchased a new dual capaitor and tried to wire to original wiring diagram however there are two brown wires on the fan motor instead of one purple. Have tried wiring with both wires to F on capacitor and with just one brown to F on capacitor both does same as before with whining sound from fan but not turning. Fan blades spin freely without power but hard to turn when power is on.
Katjahn is offline   Reply With Quote
Old 07-20-2011, 01:47 PM   #2
JJboy's Avatar
Bad motor
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
The Following User Says Thank You to JJboy For This Useful Post:
Katjahn (07-20-2011)
Old 07-20-2011, 02:36 PM   #3
Replaced motor and capacitor and it's working great. Hope it stays that way.
Old 07-20-2011, 08:39 PM   #4
JJboy's Avatar
Good
Using Gas heat during Defrost mgroves HVAC 15 12-18-2010 05:51 PM
New Heat Pump Problems Cooling Zombify HVAC 2 04-06-2010 03:42 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 08:13 PM
New Install - Heat Pump Woes... mark1210 HVAC 7 03-07-2010 09:14 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
