Heat Pump Fan Has Stopped Working - HVAC - DIY Chatroom Home Improvement Forum
Old 12-15-2010, 12:49 AM   #1
Rewards Points: 26
Hi All,
I've got a Rheem heat pump outside and the fan recently stopped working. I was able to spin it with a screwdriver and it started working each time i did that, but apparently my luck has run out. When you try to spin it now, it is sort of hard to turn, and it doesn't start up.
I suspect i'm in for a fan motor? If that's the case, does anyone know a good place to order from, and what should i do with the heat pump until i get it? It's been in the 20s here in Florida.
Thanks,
Steve
TurboSteve is offline   Reply With Quote
Old 12-15-2010, 02:50 AM   #2
Originally Posted by TurboSteve View Post
Hi All,
Thanks,
Steve
Sorry you having a problem Steve.
You can copy the model and seial # fm the unit or take out the fan and Google the model and serial number. You can pick one up for a bout $200.
Some places more and some places less.
The run capacitor should be replaced too. In fact take the old run cap out and take to a local hvac or motor shop to test it. If it
s bad you might only need the cap. But don't get your hopes up.
Cap cost about $60 (again depends where you buy it.-
hvaclover is offline   Reply With Quote
Old 12-15-2010, 12:40 PM   #3
Rewards Points: 26
Motor was shot, cap was good. Found a relatively local mom and pop shop that had the new fan for $165. Glad i took a picture of the wires before i took them off.
Thanks everyone.
Steve
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
Heat pump ice up signpainter HVAC 9 01-02-2012 09:44 AM
Brand new Carrier Infinity 16 Heat Pump Stopped Working I think needmyac HVAC 3 07-07-2009 06:12 PM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 11:49 AM
heat pump not working kyleGR HVAC 2 05-30-2006 02:35 PM
