Heat Pump Extreme Cold Weather - HVAC - DIY Chatroom Home Improvement Forum
Old 11-23-2010, 08:27 PM   #1
heat pump extreme cold weather
I just finished a cabin and it has a heat pump with the emergency electric back up. The temp. has dropped it is suppose to get down to -5 F tonight. I am wondering if I need to worry about ice build up on the unit or will the electric part just take over. I set the temp to 60 F when I left.
warnerww is offline   Reply With Quote
Old 11-23-2010, 08:36 PM   #2
No worries. The HP will be fine. The electric will also kick on when the HP cant keep up .
Old 11-23-2010, 08:36 PM   #3
HVAC / Plumbing
ice will build up on the unit. it will have to go into defrost mode. all hp's do this if there working properly
kenmac is offline   Reply With Quote
Old 11-23-2010, 08:40 PM   #4
Thanks very much for the quick responses. I was worrying. I almost got in my truck and made the drive (didn't want to but almost did it). I never expected it to get that cold in November.
Old 11-23-2010, 08:44 PM   #5
HVAC / Plumbing
wish it would get cold & stay cold here. I think it was 75* here yesterday & today
Old 11-23-2010, 08:52 PM   #6
Kind of hard to snowmobile when it is 75
Old 11-23-2010, 09:28 PM   #7
HVAC / Plumbing
we never do that here. Don't even know where I would buy 1 if I needed it
Old 11-27-2010, 06:37 PM   #8
OK I went up to the cabin and everything was great. My next question is at what temp. do I just turn off the heat pump and just use electric heat. It will be around 35 to 0 degrees the rest of the winter. I am paying about 5 cents (does that matter) a kilowatt hour. Or do I just leave the heat pump on all winter?
Old 11-27-2010, 06:48 PM   #9
An old Tradesmen
Rewards Points: 6,848
Depends on the efficiency of the heat pump.
Some are still economical to use at -10F outdoor temp. others lose their efficiency at 10F outdoor temp. And some at higher temps.
Post brand and model number. Someone may know about yours.
Old 11-27-2010, 06:58 PM   #10
paperwork is up at the cabin so I will have to wait and post again when I get a chance to get up there.
Old 11-29-2010, 07:48 PM   #11
Wink
Good answer Our 3.5 ton 12 seer York heat pump can run nearly continuously from -10F to -20F dependant on the wind outside. The temperature from the forced air registers is still in the 80's. Our Invensys thermostat is set to restrict the back up strip heat from energizing until it is -15F. In these temperatures the heat pump can run continously for days. However at the same time our avg electric bill is $126/month for our two story 5 bedroom home. At some point in extreme cold temperatures the heat loss from the house dependant on build and insulation is more than what the heat pump can replace.
lorenztl is offline   Reply With Quote
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 03:59 AM
New Heat Pump Problems Cooling Zombify HVAC 2 04-06-2010 03:42 PM
New Install - Heat Pump Woes... mark1210 HVAC 7 03-07-2010 09:14 AM
Which honeywell thermostat should I buy for my Carrier heat pump? mannypp HVAC 29 01-30-2010 02:21 PM
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 12:27 PM
