Old 11-15-2012, 12:52 PM   #1
Heat pump doesn't shut off
I've recently noticed that my thermostat will say that the inside temperature is at the desired temp but the heat pump will still be running unless I cut off the unit at the thermostat. When I start it back up, everthing works fine including the air handler but when it gets back up to temp, the air handler cuts off as it should but the heat pump does not.
jdmitche is offline   Reply With Quote
Old 11-15-2012, 02:00 PM   #2
Willing to listen
Y (compressor) output relay in thermostat could be sticking, since the blower is a seperate G (fan) output relay and it seems to be behaving.
Outdoor unit either has to have a 24V Y output coming to it telling it to run, or a stuck contactor that is keeping the unit running without Y present.
Done That is offline   Reply With Quote
Old 11-15-2012, 05:13 PM   #3
If it doesn't go above the thermostat setting don't worry about it. Thermostats display whole numbers but read in tenths so set on 72 and room 72 display could mean it has another 9/10th of a degree to heat up before the thermostat satisfies.
Heat pump starts initially but will not come back on to maintain temps johnniebravo HVAC 53 11-22-2011 08:48 PM
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 8 11-19-2011 11:45 PM
VisionPRO Setup Functions & Heat Pump infoskr HVAC 31 03-18-2010 02:15 PM
New Heat Pump..questions? ddave23 HVAC 4 03-05-2010 06:13 AM
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 11:28 AM
