Old 01-12-2013, 12:59 PM   #1
Heat pump defrost mode??
I had a service tech check out my unit, he jacked up the heat first off. After a while the fan shut off outside and he said it went into defrost mode. It was only about 60 and damp outside. I thought this was strange. The coils started to frostup and it just buzzed for the longest time. Why would it frost up if it was supposedly in defrost mode. He said I may have a bad defrost control board. Any suggestions out there?
stesyl is offline   Reply With Quote
Old 01-12-2013, 01:02 PM   #2
It's a carrier model 38eya060310
Old 01-12-2013, 04:11 PM   #3
An old Tradesmen
Could be a problem with the fan motor, the dual run cap, reversing valve, or the defrost board. May or may not have been in defrost. If the RV doesn't move over while in defrost the coil will frost.
Trane Heat pump - clogged filters cause failure? bigdyl HVAC 2 12-12-2012 04:27 PM
heat pump freezing problem av-geek HVAC 8 02-02-2012 08:16 PM
Heat Pump Crisis Part II Doc Holliday HVAC 58 12-07-2011 10:14 PM
Heat Pump Crisis, Help! Doc Holliday HVAC 14 12-02-2011 10:22 PM
Using Gas heat during Defrost mgroves HVAC 15 12-18-2010 06:51 PM
