Old 01-19-2013, 08:24 AM   #1
raylo32's Avatar
heat pump coil gurgling
Visiting some folks and when the heat pump kicks on for a heat cycle they get about 3 seconds of very loud gurgling flow noise in the indoor coil. Does this sound like air in the system? Or is the TXV bleeding pressure down when it is off? Otherwise it seems to work OK.
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 01-19-2013, 08:39 AM   #2
An old Tradesmen
Some liquid refrigerant is probably in the coil or the large line near the coil and your hearing it move through the indoor coil. Not an unusual noise for some systems.
Trane Heat pump - clogged filters cause failure? bigdyl HVAC 2 12-12-2012 04:27 PM
What did I do? Heat Pump isn't working ChrisDIY HVAC 10 03-14-2011 04:55 PM
Heat pump and Honeywell 8000 questions. jyoderz HVAC 14 04-06-2010 03:26 PM
VisionPRO Setup Functions & Heat Pump infoskr HVAC 31 03-18-2010 02:15 PM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 03:11 PM
