Heat Pump Check Up - HVAC - DIY Chatroom Home Improvement Forum
Old 02-05-2013, 09:56 AM   #1
Rewards Points: 50
Heat Pump check up
Is there a better time or best time (summer winter/hot cold) to do a heat pump check up?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 02-05-2013, 11:28 AM   #2
An old Tradesmen
Rewards Points: 6,470
Spring or fall. When it can be checked in cooling mode also.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
digitalplumber (02-05-2013), hvactech126 (02-05-2013)
American standard heat pump question. SS laser HVAC 5 01-04-2012 10:35 PM
Drainage under packaged heat pump salonica HVAC 18 12-25-2011 08:07 AM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 01:19 PM
Water Source Heat Pump installation JLMitchell HVAC 6 11-30-2009 04:23 AM
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 04:05 PM
