Heat Pump Capacitor - HVAC - DIY Chatroom Home Improvement Forum
Old 11-25-2012, 05:59 PM   #1
Heat Pump Capacitor
My outside condenser fan (heat pump) is not working, but it does spin when I turn it by hand. I suspect the capacitor is bad (it is a dual capacitor). If I attempt to replace the capacitor, do I need to take any electrical precautions, except for turning off the breaker? Will the capacitor discharge when I handle it?
ChuckieP is offline   Reply With Quote
Old 11-25-2012, 07:26 PM   #2
Rewards Points: 616
it might.... wear gloves...or discharge it with a screw driver......
carmon is offline   Reply With Quote
The Following User Says Thank You to carmon For This Useful Post:
ChuckieP (11-25-2012)
Old 11-25-2012, 09:01 PM   #3
So, you're saying I should short the terminals with a screwdriver? or ground the terminals to the can with a screwdriver?
Old 11-25-2012, 09:03 PM   #4
Items wanted: Time
Rewards Points: 150
any insulated tool will work, wear safety glasses.
NiNe O is offline   Reply With Quote
The Following User Says Thank You to NiNe O For This Useful Post:
carmon (11-25-2012)
Old 11-26-2012, 10:06 AM   #5
Rewards Points: 1,574
Obviously, shut off power to the unit before you do so!
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
ChuckieP (12-03-2012)
Old 12-03-2012, 09:34 AM   #6
Capacitor - Wrapup
Thanks for all the help with my capacitor.
Ordered a replacement capacitor, online, for my Trane Heat Pump.
installed it in 10 minutes;
works like a champ!
The Following User Says Thank You to ChuckieP For This Useful Post:
NiNe O (12-03-2012)
gas furnace efficiency, hybrid heat pump, and payback times av-geek HVAC 1 06-22-2012 08:46 AM
Heat Pump Efficiency Help! horseonthefly HVAC 5 03-16-2012 05:14 PM
Heat pump starts initially but will not come back on to maintain temps johnniebravo HVAC 53 11-22-2011 08:48 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 09:13 PM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 09:34 PM
