Heat Pump Capacitor - HVAC - DIY Chatroom Home Improvement Forum
Old 07-16-2011, 01:12 PM   #1
SRQ
heat pump capacitor
installed new capacitor/ fan runs slower than normal/could i have reversed HCC and Fan connectors? Compressor can't seem to fire up and run. I hear it click but not start.
SRQ is offline   Reply With Quote
Old 07-16-2011, 01:54 PM   #2
JJboy's Avatar
What was the reason to replace the capacitor?
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-16-2011, 02:14 PM   #3
SRQ
Re: Heat Pump Capacitor-HELP!
Hello:
It is getting very hot down here in Florida. Your assistance in the matter of my capaicitor problem would be very much appreciated. The wiring diagram in the unit doesn't match the color of the leads going to the capacitor. The capacitor has three terminals(Fan, HRR and blank). I have an orange to the blank, a brown to the the fan and a darker brown to HRR. Do the brown leads need to be reversed?
Old 07-16-2011, 02:17 PM   #4
SRQ
Re: Capacitor
The air coming out of the vents was hot. The air handler was working fine, but the compressor outside had a non-functioning fan. Took out the fan and had it tested(rated OK). The capacitor was rated as non-functioning during its test.
Old 07-16-2011, 02:32 PM   #5
JJboy's Avatar
If you replaced the dual capacitor, and the fan is running slow. I guess, the motor bearing is bad. You have to replace it.
Also, you need make sure the condenser coil is clean.
Old 07-16-2011, 02:40 PM   #6
JJboy's Avatar
F - goes to the Fan
H (HRR) - goes to the Compressor
C (black) - goes to the contactor
Old 07-16-2011, 02:49 PM   #7
SRQ
Re: Capacitor
The motor was tested yesterday at a motor shop. It ran full out. Could I have reversed two of the three connectors on the capacitor to have caused this problem?
Coils are clean and unit ran fine before fan stopped running the other day.
Old 07-16-2011, 02:59 PM   #8
JJboy's Avatar
Reading your other post, it seems you reverted both wires. Since the wires are brown and dark brown.... just connect the brown wire coming from the fan to F on the capacitor, and the another brown is coming from the compressor on H on the capacitor.
Old 07-16-2011, 03:24 PM   #9
SRQ
Re: capacitor
If I reverse the wires, can an damage occur to the compressor?
Old 07-16-2011, 03:28 PM   #10
JJboy's Avatar
Just install the way should be.
Old 07-16-2011, 04:05 PM   #11
An old Tradesmen
Rewards Points: 7,356
Merged your threads about this. So that it not confusing to anyone that tries to help you.
Old 07-16-2011, 04:18 PM   #12
SRQ
Re: Capacitor
Thanks for merging the comments.
My leads are orange, brown and light brown. The colors on the units wiring diagram are different, that why I am confused. Also, my markings on the wires came loose before I had a chance to replace the capacitor. Thats why I am confused. I am afraid that if I don't get the wires right, I might damage the compressor.
Old 07-16-2011, 04:31 PM   #13
JJboy's Avatar
Like I said, You need to trace the wires. you have 3 wires right? they are coming from compressor, fan and contactor......
The wire is coming from FAn you have to connect at F on the capacitor
The wire is coming from compressor you have to connect at H on the capacitor
the another wire goes to C on the capacitor.
post some pics
The Following User Says Thank You to JJboy For This Useful Post:
SRQ (07-16-2011)
New Heat Pump Problems Cooling Zombify HVAC 2 04-06-2010 03:42 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 08:13 PM
New Install - Heat Pump Woes... mark1210 HVAC 7 03-07-2010 09:14 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
What temp does my Heat Pump stop producing good heat or what is the threshold? twilightcall HVAC 15 02-12-2010 09:46 PM
