Heat Pump /// Cambridge Ontario (normally -20oC To + 35oC) - HVAC - DIY Chatroom Home Improvement Forum
Old 11-05-2010, 07:50 PM   #1
SFX Group's Avatar
Send a message via MSN to SFX Group Send a message via Skype™ to SFX Group
Heat pump /// Cambridge Ontario (normally -20oC to + 35oC)
Hi
I will be removing an older furnace (with Aircon), however i am looking at the heatpumps, i understand how they work, but with temps from -20 in winter to +35 in summer will it be worth it?
Will the extra money never get regained over the fact it will need a standard Aircon unit / gas unit for heat?
Many Thanks
Ashley
SFX Group is offline   Reply With Quote
Old 11-05-2010, 07:54 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Just my $.02
Stick with a gas furnace 95% and a regular A/C.
With temps like that a heat pump is not efficient
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 11-05-2010, 08:04 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,144
I agree. They are not cost effective below -5C and we get lots of that. High efficiency furnace is more comfortable and costs less to run in the Great White North.
Heat pump /// Cambridge Ontario (normally -20oC to + 35oC)-bobanddoug1.jpg
Old 11-06-2010, 12:02 AM   #4
SFX Group's Avatar
Thanks for the input, will put a standard furnace/aircon
Many Thanks
Ashley
Many Thanks
Ashley
Copyright 2011 - www.ashleygriffin.ca
Heat pump and Honeywell 8000 questions. jyoderz HVAC 14 04-06-2010 03:26 PM
New Install - Heat Pump Woes... mark1210 HVAC 7 03-07-2010 10:14 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 09:34 PM
What temp does my Heat Pump stop producing good heat or what is the threshold? twilightcall HVAC 15 02-12-2010 10:46 PM
Brand new Carrier Infinity 16 Heat Pump Stopped Working I think needmyac HVAC 3 07-07-2009 07:12 PM
