Old 07-16-2012, 03:21 PM   #1
Heat pump (Bryant) in CT?
I was hoping for some constructive thoughts about heat pumps (i.e., specifically Bryant)... here is some info...
House in CT is well built, insulated, etc. (I had energy audit done and made some minor adjustments), 24 years old with original Burham hot water oil burner (parts replaced and works well) and Lennox 4 ton A/c unit.
Thinking of replacing the Lennox. One company measured house, etc. and said the new Bryant AC/heat pump units can work well near single temp digits. If true<?> once I see the numbers I can figure out if I save any oil costs and go for a combo AC/heat pump vs just a replacement AC unit (current Lennox seems to work OK). However another guy told me that heat pumps only work well under the 40s. I once lived in south and they did seem to not work well below 40 (and electric coils come on).
Any thoughts/experience with the Bryant?
Oh, I will be solar so generate my own electricity.
Thx
desmo907 is offline   Reply With Quote
Old 07-16-2012, 04:29 PM   #2
biggles's Avatar
ground source HPS then you don't have to worry about the 40F condenser and the outside going below it..which is when it starts loosing efficantcy.then when you defrost your running colling in the winter with the resistance heat making up for the 40F off the air handler...with it 20F outside.ground source you get a constant 50-60 during the winter and bang the heat wit minimal defrosting cycle if any... http://www.youtube.com/watch?feature...JHtK91vZo&NR=1
Old 07-16-2012, 05:39 PM   #3
E2 Electrician
stickboy1375's Avatar
I live in CT and run a heat pump, I have oil as a backup and I cut out the Heatpump at 32* outside temp, I'm very happy with this setup and cutout temp, although, it will heat my house at lower temps, it won't delivery the efficiency either.... I own a tempstar 2 Stage Heatpump, IMO, I highly recommend it. I used a 1/2 a tank of oil last year, I have a heatpump/electric water heater as well, i ditched the oil fired water heater, couldn't stand burning oil all summer just for hot water.
Old 07-16-2012, 06:20 PM   #4
Thx.
I suspect my AC is nearing end of life and it certainly is not efficient (thought I hardly used it until this past year).
I also heard of the Carrier Greenspeed units.... can be used to ~0 deg.
I was thinking the same... oil baseboard heat in colder months. I may disconnect my hot water from the Burnham boiler too and go electric since I will be solar.
Thx
Old 07-16-2012, 06:43 PM   #5
E2 Electrician
Originally Posted by desmo907 View Post
Thx.
Thx
My 2 ton unit crapped out, and I upsized the duct work in-between all that, so for an extra 1,000 I went with the heat pump and a 3 ton unit, I love the 2 stage aspect of it... I changed out the blower in my furnace to accommodate the 2 stage outdoor unit... I hardly EVER feel a temperature swing in my house unless the actual furnace kicks on and blasts the huge amount of hot air...
Old 07-16-2012, 07:38 PM   #6
An old Tradesmen
If you have enough solar panels to run the heat pump. then it will cost less to use it to heat with even when its zero outside, and colder.
Old 07-16-2012, 07:57 PM   #7
You also might want to check out a couple Lennox units that are already set up for solar power. I believe the models are the xp17 and the xp21.
Old 07-16-2012, 08:09 PM   #8
An old Tradesmen
Nothing actually super special about the condenses from lennox. its just that Lennox's solar panel have the inverter on them, and supply 240 volt from the panel. lennox just uses their condenser as a raceway.
gas furnace efficiency, hybrid heat pump, and payback times av-geek HVAC 1 06-22-2012 08:46 AM
Heat Pump Efficiency Help! horseonthefly HVAC 5 03-16-2012 05:14 PM
Heat Pump Thermostat HELP!!! MichaelG HVAC 22 12-09-2010 05:50 PM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 09:34 PM
New Heat Pump..questions? ddave23 HVAC 4 03-05-2010 06:13 AM
