Heat Pump Blows Cold For Awhile - HVAC - DIY Chatroom Home Improvement Forum
Old 10-01-2011, 04:59 PM   #1
Unhappy
Heat Pump blows cold for awhile
Hi all! I'm the proud owner of a crappy 3 ton Ducane heat pump that is under 7 yrs old. Had a major R22 leak last fall, had the leak repaired, refilled w 7#s of freon. Replaced contactor, condenser fan, a capacitor and defrost control board because it had a large black burn mark when fan went out. Had been running fine until recently. Also the unit doesnt seem to drain properly, there's always alot of condensation lying at the bottom of the unit. Some of it drains off but not all. Doesnt appear to be any obstruction in the pvc drain tube. It's a rooftop unit, brilliant in the sonoran desert
So the problem now is that it runs fine & cold for the 1st 20 mins or so (17-18deg split) and then slowly starts to blow warmer until its about a 5 deg split & it just runs until it blows warm. Filter is brand new so Im not sure if its freezing or low on freon again or what. Then I'll shut it off for an hour or so, turn it back on & its fine for awhile & repeats the same thing again.
Any ideas would be greatly appreciated, thanks!! 1340 sq ft, 1 floor
Pantera99 is offline   Reply With Quote
Old 10-01-2011, 05:15 PM   #2
I would suspect moisture in the refrigerant system.
Master of Cold is offline   Reply With Quote
Old 10-01-2011, 05:32 PM   #3
"In" the refrigerant system? Like inside the pipes? Or inside the unit itself? IDK if the drain pan is leaking or perhaps the whole unit isn't level. The excess water in the unit sure can't be helping. If u mean inside the pipes, what can be done about that? IDK alot about HVAC so forgive me if this is a stupid question, thanks!!
Old 10-01-2011, 05:57 PM   #4
JJboy's Avatar
If moisture is found inside the system (mixed with refrigerant ). All refrigerant has to be recovered . After that, unit needs to be triple evacuated with 500 microm on the last cycle. Then reload the unit with new refrigerant. Also is good to add filter drier.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-01-2011, 06:07 PM   #5
If you work for me, filter drier is mandatory...
Old 10-01-2011, 06:16 PM   #6
JJboy's Avatar
Old 10-01-2011, 07:58 PM   #7
Wow, ok I never even thought about that. That would certainly explain why it acts sporadically. I would assume R22 had some sort of moisture repellant in it, I know it has some sort of mineral oil or something but I guess it doesnt. I've popped off a panel when I thought it was 'frozen" but I was looking for ice on the outside of the evap coil & if anything its overly wet on the bottom of the unit getting into the unit's insulation. Every time I shut it off for an hour or so its fine upon startup again. I know how to get ahold of a couple of HVAC techs, I'll run this idea by them. Thanks for the help. Every time I call a company out they just wanna sell me a new unit. I'm like it's 6 freakin' years old ya know??
Old 10-01-2011, 08:07 PM   #8
JJboy's Avatar
6 years old is a baby system.
Heat Pump Not Blowing Cold RB101011 HVAC 18 09-29-2011 10:03 PM
Trane unit not switching from heat pump to Furnace when weather gets cold. Jimw606 HVAC 1 09-27-2011 04:03 PM
What did I do? Heat Pump isn't working ChrisDIY HVAC 10 03-14-2011 03:55 PM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 06:53 PM
heat pump cut off set point oldswab HVAC 4 12-02-2009 02:09 PM
