Heat Pump Blower Problems - HVAC - DIY Chatroom Home Improvement Forum
Old 05-05-2012, 11:09 AM   #1
heat pump blower problems
my blower motor went out. i changed the copasitor and it didnt help. then i changed the motor. now when i turn the stat to cool, the blower comes on for 4 sec. and then it goes off and on in 2-3 sec. i have checked the relay and it makes contact and stays closed when this is happening. this is a trane heat pump unit. can anybody help me?
Last edited by mbaker999; 05-05-2012 at 11:46 AM. Reason: better description of problem
mbaker999 is offline   Reply With Quote
Old 05-05-2012, 03:44 PM   #2
An old Tradesmen
Rewards Points: 7,270
Are you sure you wired the motor right.
The Following User Says Thank You to beenthere For This Useful Post:
hvactech126 (05-05-2012)
Old 05-05-2012, 03:56 PM   #3
i'm pretty sure i did
Old 05-05-2012, 05:20 PM   #4
An old Tradesmen
Might want to make sure you don't have it wired wrong.
Post what wires go where. Also, is it an OEM motor, or third party motor.
Heat Pump Efficiency Help! horseonthefly HVAC 5 03-16-2012 04:14 PM
Problems with new heat pump - return? JOAN73 HVAC 1 02-09-2011 05:46 PM
Bizarre Heat Pump and Blower Behavior gatorinsc HVAC 3 01-11-2010 03:32 PM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 06:15 AM
heat pump cut off set point oldswab HVAC 4 12-02-2009 02:09 PM
