Heat Pump Auxilary Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 02-10-2010, 08:27 AM   #1
Heat pump auxilary heat
I have a Carrier heat pump about 8 years old. I checked the amperage draw and it was 30 amps taken with an ampmeter around one of the hot wires. This reading was taken at the disconnect on the inside blower assembly. When the heat pump is running and the thermostat is not showing active auxilary heat, there is no reading. This is a split unit and a separate power supply goes to outside. Im I correct in assuming that at this stage of operation, it is not pulling much more current then my 4K watt portable heater?
Giles is offline   Reply With Quote
infinity heat pump always on aux heat below 40 degree hirrlinger HVAC 4 07-18-2010 12:51 PM
heat pump install wiring question fireman0175 Electrical 1 08-03-2009 12:12 AM
Brand new Carrier Infinity 16 Heat Pump Stopped Working I think needmyac HVAC 3 07-07-2009 06:12 PM
Heat pump problem, indoor fan blows in heat but not A/C or "on" lngroller HVAC 2 06-03-2009 07:55 AM
Ductless Heat Pump for Garage?? brittlediabetic HVAC 25 04-23-2009 02:28 PM
