Heat Pump Aux Heat Runs (almost) Always - HVAC - DIY Chatroom Home Improvement Forum
Old 01-26-2010, 11:09 PM   #1
Exclamation
Heat pump aux heat runs (almost) always
Good evening friends.
My wife and I just moved in to our newly built house. One of our first projects we decided on was installing a programmable thermostat that matched our decor. We decided on the Honeywell RTH7600D.
Ever since we wired up the new Tstat, the aux heat seems to be running all the time and for no reason. I will have it set to 70... the house temp is also at 70, then, after a couple of minutes, the aux heat clicks on, yet the temperature never went down. It will stay on for a couple minutes then click back off. If you wait another few minutes, it will click back on. Meanwhile, the temp never went below 70 and the set temp never went above 70.
I would prefer to only use the aux heat in extreme situations... like 15 degrees from set temp.
I also had a couple setup questions that may answer my question above:
What should I set the 0190 option to? I can set it to 0 or 1, depending on if I wired up O or B to O/B. Well, my old tstat had B/O and the new one has O/B...? I've been feeling heat with the system, so I think I have it set up correctly.
I'm not sure if you can tell or not, but I'm extremely new to home projects. I have the old tstat, notes I've taken during the install, and some pictures of the equipment if needed. Thank you so much for your assistance!
snappjay is offline   Reply With Quote
Old 01-27-2010, 12:37 AM   #2
Houston204's Avatar
Rewards Points: 556
If your heat pump outside is a Rheem, Ruud or Weatherking, (I've also seen old Mammoth Geothermals like this) option 190 = 1.
All other brands will need option 190 to be 0.
The Honeywell VisionPro TH8320 and the TH8321 (with the optional outdoor sensor) allow you to lockout Aux heat untill outdoor temp is 40 degrees.
Houston204 is offline   Reply With Quote
Old 01-27-2010, 12:40 AM   #3
Houston204's Avatar
Rewards Points: 556
What is your option 170 setting?
Old 01-27-2010, 06:39 AM   #4
An old Tradesmen
Rewards Points: 6,060
Why would you want the temp in your house to drop to 55 before the aux heat kicks on.
If thats what you want. Then just set the thermostat to 55. You'll be cold either way.
Wrong stat if you want the temp to have to drop more then before bringing on the aux heat.
Old 01-27-2010, 08:14 AM   #5
Thank you, as always, for the quick responses.
Just as a side note, here is how my wiring looks:
C to C
G to G
Y1 to Y
B/O to O/B
R to R with RC Jumper
W2 to Aux
E to E
No wire to L
Also, is the 1/2 degree aux kick on normal? Again, I am a noobie in every respect and I thank you for your time.
Old 01-27-2010, 08:20 AM   #6
An old Tradesmen
With that line of thermostat yes.
There are some ways to hold it off a little longer. but not much. Its a comfort thermostat. So its designed to hold a very tight temp tolerance.
Big temp swings are not considered to provide comfort.
If you have your aux CPH set to factory recommended 9CPH. Change that to 3. It will hold off the aux heat for a little longer.
Also. Check to make sure the hole where the wires come through is sealed. A cool draft can make it bring on the aux quicker then needed also.
Old 01-27-2010, 08:21 AM   #7
My 170 is set to 7. Would setting it to 2 completely turn off the aux heat?
Old 01-27-2010, 08:24 AM   #8
Thanks for the info! I'll check the sealing as soon as I am able. I may be able to stuff something in there to help out.
How would I check the aux CPH? Thanks guys, you are a huge help to me and the wife.
Old 01-27-2010, 08:30 AM   #9
An old Tradesmen
Installer set.
0250 should be your aux heat CPH setting. See what its set to. Probably at factory setting of 9.
Old 01-27-2010, 08:35 AM   #10
Installer set.
I'm actually not seeing a 0250 option.
Here is the hookup manual for the Tstat:
http://customer.honeywell.com/techli.../69-2206EF.pdf
On page 18, it jumps from 0240 to 0270...
Old 01-27-2010, 08:49 AM   #11
An old Tradesmen
I don't use the box store stats. They have some limitations that the trade stats don't.
So either 240 or 270 will be your setting to use for aux heat.
Set both of them to 3. If 240 is already at 3 and 270 is at 9. then 270 is both emergency and aux CPH setting.
Tags
aux , heat pump , honeywell
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 04:59 AM
infinity heat pump always on aux heat below 40 degree hirrlinger HVAC 4 07-18-2010 01:51 PM
Heat pump thermostat emergency switch joe913 HVAC 2 12-10-2009 01:54 PM
Ductless Heat Pump for Garage?? brittlediabetic HVAC 25 04-23-2009 03:28 PM
Please answer this question about my Carrier Heat Pump... jifmom HVAC 4 02-20-2009 12:38 PM
