Heat Pump To Aux Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 12-16-2011, 11:30 AM   #1
heat pump to aux heat
What outside temp. should it be, before changing from heat pump to aux. heat?
KBrew is offline   Reply With Quote
Old 12-16-2011, 01:35 PM   #2
Willing to listen
Rewards Points: 223
Pump is going to be cheaper that 100% electric way down into the single digits. Different answer if your aux is gas furnace. Comfort, that is, temp of air from the vents might lead to different decision, depends if that is a concern to you.
As for me, I let the pump be the primary heat source all the time and the tstat will call for electric heat as supplemental in the background when the pump alone can't keep up.
Only time I shut her down is a bad ice storm where it can't defrost properly.
Done That is offline   Reply With Quote
New heat pump wiring question jmedenf HVAC 3 10-14-2011 06:26 PM
Using Gas heat during Defrost mgroves HVAC 15 12-18-2010 05:51 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 08:13 PM
New Install - Heat Pump Woes... mark1210 HVAC 7 03-07-2010 09:14 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
