Heat Pump/air Handler Replacement - HVAC - DIY Chatroom Home Improvement Forum
Old 09-23-2010, 05:50 PM   #1
Heat pump/air handler replacement
Hi,
I've got zoned heating in a 1950's modified cape code with two Trane heat pump/air handler units that are from 1992 - one is 10 seer, the other 11. Total SF is 1650. I'm looking to replace the 11 that heats/cools the front of the house. I might add on to the back - that's why I'm thinking of waiting to replace that one.
Do I need to replace the air handler? What about the duct work - it's the round 6 inch flexible stuff? The air handler is in an outside utility shed and the ducts run through a tight crawl space, maybe 2 feet.
I was looking at the Trane XL20i or the XL16i. Would the cost difference be made up quickly with the higher efficiency?
I also see that Trane has a smaller air handler for tight spaces (2/4TFB Compact) - any reason not to get this?
Any general comments on Trane versus other manufacturers?
Thanks, Peter
baylegg is offline   Reply With Quote
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 07:15 AM
Frozen Hot Water Pipes TravisW Plumbing 11 12-10-2009 06:26 PM
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 11:28 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
can't find old replacement parts, need Air Handler coils, junkyard? sammibah HVAC 2 07-02-2006 08:43 AM
