Heat Pump Air Handler Fan - HVAC - DIY Chatroom Home Improvement Forum
Old 12-02-2008, 12:22 PM   #1
So I've got this electric heat pump air handler fan that wouldn't turn on... So I replaced the heat sequencers and got it to come on but kinda weak and only for about 5 minutes after power is restored, So I thought maybe the transformer was bad and replaced that. Same thing. I checked the fan and it spins smooth and free with no resistance. If the CAP or blower motor was bad it wouldn't turn on at all, right? So what am I missing here?
SgtMaj is offline   Reply With Quote
Old 12-02-2008, 12:40 PM   #2
Are you getting power to the motor and cap when this happens?
dac122 is offline   Reply With Quote
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 10:28 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 11:49 AM
Tax Credit: Buy new heat pump & handler now or 2006 toolmanwannabe HVAC 1 10-05-2005 11:41 AM
