Heat Pump / Ac Unit Vs Electric Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 01-12-2011, 06:56 PM   #1
heat pump / ac unit vs electric furnace
I live in Montreal. I already have an electric furnace and want to get central air. Should I opt for the heat pump instead of just central air unit? Will it really save me money in thee long run?
Tony
ellebt is offline   Reply With Quote
Old 01-12-2011, 07:45 PM   #2
Yes. The heat pump will cost 3-4 times less to run then electric elements when it's over 40F out. When it drops down to twenty the HP will still be half the cost to run as the elements. When it gets in the single digits the HP and elements will run at the same time so it's still cheaper then straight electric heat.
The difference between using a HP and straight electric heat in Dec and Jan. here is about $200 a month. Heat pumps don't cost too much more then AC and will save enough to pay for difference in one heating season. The rest of its life is money in the bank.
Old 01-12-2011, 08:35 PM   #3
Rewards Points: 6,652
There are the Acadia Heat pumps that would work in your climate http://www.gotohallowell.com/
Old 01-12-2011, 10:22 PM   #4
An old Tradesmen
Rewards Points: 6,448
They are last I knew. Not producing units anymore, and some distributors are not selling the ones they have in stock. Due to the company not being on sound ground again.
Old 01-12-2011, 10:22 PM   #5
An old Tradesmen
Tony
What area are you in?
heat pump cut off set point oldswab HVAC 4 12-02-2009 03:09 PM
Water Source Heat Pump installation JLMitchell HVAC 6 11-30-2009 04:23 AM
new carrier heat pump furnace wont cool home wisjr HVAC 8 08-12-2009 01:23 PM
Wiring a RobertShaw 9870i to Gas Furnace & Heat Pump jerfer HVAC 11 12-21-2008 10:09 PM
Better for heat pump or electric coil/strip? Lori 48616 HVAC 5 09-05-2008 03:28 PM
