Heat Pump AC Freezing Up - HVAC - DIY Chatroom Home Improvement Forum
Old 10-08-2011, 01:47 PM   #1
I have a thru the wall AC and heater unit, the kind that are in motel rooms. It is a heat pump system. The unit was on AC low for 2 days and froze up. What could cause this?
Tim
tgillis is offline   Reply With Quote
Old 10-08-2011, 04:35 PM   #2
Rewards Points: 6,652
A leak somewhere.
Old 10-08-2011, 07:47 PM   #3
A freeze up comes from having low air flow across the coil, or a refrigerant leak.
Master of Cold is offline   Reply With Quote
Old 10-08-2011, 08:42 PM   #4
An old Tradesmen
Rewards Points: 6,568
How cold was the room and the outdoor temp during these 2 days?
Old 10-09-2011, 10:27 AM   #5
The day time outside temp was 80 and the room temp before the unit froze up was about 72
Old 10-09-2011, 01:42 PM   #6
An old Tradesmen
Dirty air filter, coil, or low on charge.
Heat pump vs AC unit docmattman HVAC 11 07-31-2011 12:24 PM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 07:53 PM
Heat Pump Thermostat HELP!!! MichaelG HVAC 22 12-09-2010 05:50 PM
Heat pump vs in floor heat mugen HVAC 5 03-02-2010 09:18 PM
Heat Pump Lines freezing dec1000 HVAC 1 05-09-2009 10:21 PM
