Heat Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 02-08-2011, 07:13 AM   #1
Heat Pump
I just bought a house for my daughter and it has a heat pump system in it. The house had been setting for a couple years when I bought it, it is around 2,000 Sq ft. Not sure if it is working properly we just got our first heat bill and it was over 500.00 which I thought was an awful lot. The house is insulated well could anyone give me insight on what may be happening. And things I might be looking for to see what is causing the high electric bills. Thanks for any help in this matter.
fieldman2 is offline   Reply With Quote
Old 02-08-2011, 08:41 AM   #2
Rewards Points: 150
What have the outside temperatures been like where she lives in the last month? Does she have emergency electric coil backup heat? That can be very expensive.
Make sure the emergency heat is not coming on automatically at night. Some thermostats are programmed so that it comes on when the temp falls only 3 degrees below the setting.
NancyNGA is offline   Reply With Quote
Old 02-08-2011, 02:37 PM   #3
"HVAC Pro"
seatonheating's Avatar
You need a Honeywell VisionPro 8000 thermostat with outdoor sensor so you can lock those heat strips out at milder temperatures.
What area are you located in? Possibly someone on this board is in her area and can help her out.
seatonheating is offline   Reply With Quote
Old 02-08-2011, 06:00 PM   #4
Probably a good idea to call a pro out on the one. Could be a host of things going on that cause the strips to run too much and your daughter isn't going to know how to check any of them. Should be less then a fifth of that electric bill to get the system diagnosed.
Old 02-08-2011, 06:58 PM   #5
An old Tradesmen
Rewards Points: 7,318
Have you'her been setting the temp back at night, and then up again in the morning. And then setting it back while at work and then back up when home? If so, this will raise your heating bill when you have a heat pump with electric aux heat.
Old 02-08-2011, 07:11 PM   #6
fabrk8r
fabrk8r's Avatar
Check the refrigerant charge...the unit may be on emergency heat all the time if the charge is low or gone due to a leak. I've seen it happen when the evaporator coil develops a small leak.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 02-09-2011, 12:43 AM   #7
HVAC Supermodel
unicursalhex's Avatar
Rewards Points: 150
Can I be your son?
unicursalhex is offline   Reply With Quote
Using Gas heat during Defrost mgroves HVAC 15 12-18-2010 05:51 PM
New Heat Pump Problems Cooling Zombify HVAC 2 04-06-2010 03:42 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 08:13 PM
New Install - Heat Pump Woes... mark1210 HVAC 7 03-07-2010 09:14 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
