Heat Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 01-29-2011, 04:07 PM   #1
heat pump
I have a 15 year old Heil heat pump and a new Honeywell t-stat. How can I keep the auxliary heat strips from coming on with only a 1 degree differential in room temp and set temp?
wildcat89 is offline   Reply With Quote
Old 01-29-2011, 07:08 PM   #2
An old Tradesmen
Rewards Points: 7,770
What model number is the thermostat.
Old 01-30-2011, 02:01 AM   #3
HVAC Supermodel
unicursalhex's Avatar
Rewards Points: 150
The droop settings may be outa whack. If I were you I would get a Honeywell Visionpro IAQ with an outdoor sensor. This way the changeover is controlled by temperature the way it should be.
unicursalhex is offline   Reply With Quote
Old 01-30-2011, 04:10 AM   #4
An old Tradesmen
Below balance point/aux lock out temp, the heat strips will still come on with less then a 1 degree temp difference.
Old 01-30-2011, 01:57 PM   #5
The t-stat is Honeywell th5200d. How do you set the aux lock out temp that you referred to?
Old 01-30-2011, 03:13 PM   #6
An old Tradesmen
The TH5000 series(there are more numbers then you posted) doesn't have lock out ability.
Old 01-30-2011, 05:14 PM   #7
Do I have any other options with the equipment I have? I don't believe my heat strips came on so often last winter. Also, should the outside fan always run when the heat pump is on?
Old 01-31-2011, 02:58 AM   #8
HVAC Supermodel
Rewards Points: 150
Lame... IAQ!
Old 01-31-2011, 04:25 AM   #9
An old Tradesmen
Lame... IAQ!
Even on an IAQ, once the outdoor temp is below lock out, the strips will come on with less then a 1 degree difference. The only saving grace, is that many areas, the outdoor temp doesn't drop below the IAQ's lowest lockout temp, and you can use 2 degree drop.
Old 02-01-2011, 01:37 AM   #10
HVAC Supermodel
Rewards Points: 150
Lame!!!
Old 02-01-2011, 03:33 AM   #11
An old Tradesmen
Lame!!!
Just the way comfort thermostats work.
Using Gas heat during Defrost mgroves HVAC 15 12-18-2010 05:51 PM
New Heat Pump Problems Cooling Zombify HVAC 2 04-06-2010 03:42 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 08:13 PM
New Install - Heat Pump Woes... mark1210 HVAC 7 03-07-2010 09:14 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
