Heat Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 01-17-2011, 08:58 AM   #1
heat pump
what size heat pump di i need for 1200 sq feet
tootsie007 is offline   Reply With Quote
Old 01-17-2011, 09:33 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,078
Ayuh,... It depends on the heat loss for that 1200sq.ft....
Old 01-17-2011, 04:58 PM   #3
As stated it depends on the house. Insulation, outside design temp, indoor temp, windows, air infiltration and even which direction the house faces all are factors. Size the heat pump for cooling though, not heating. A two stage two ton is a perfect match for most homes that size here.
Old 01-21-2011, 07:10 AM   #4
Yes Tootsie, your query doesnt say what region of the country you are in or the type of house and open windows/doors etc. I think you can do 1.5 tons generally and be efficient. Checkout the EPA and DOE govt specs. Article is a little overkill but you will learn and benefit comprehensively
http://www.homeenergy.org/archive/he...95/950509.html
hvac_dude is offline   Reply With Quote
Using Gas heat during Defrost mgroves HVAC 15 12-18-2010 05:51 PM
New Heat Pump Problems Cooling Zombify HVAC 2 04-06-2010 03:42 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 08:13 PM
New Install - Heat Pump Woes... mark1210 HVAC 7 03-07-2010 09:14 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
