Heat Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 02-06-2010, 04:37 PM   #1
Heat Pump
Have goodman 14 seer heat pump. what temperture should be coming out . It,s 30 degrees outside. how often will it go into defrost in a hour. Never had a heat pump before. thanks
spankyjc is offline   Reply With Quote
Old 02-06-2010, 06:08 PM   #2
An old Tradesmen
Rewards Points: 6,880
What temp is it in your house.
What model 14 SEER is it, and what model is the indoor unit.
How long is the defrost timer set for. That varies how often it goes into defrost once the coils temp is below 28F.
Old 02-07-2010, 03:16 PM   #3
Furnace is goodman GMV950905 Heat pup goodman 4 ton 14 seer GSH14. What temp. should heat pump out into house. 100 degrees 200?. Never had a heat pump before . Seem to run alot. Outside sensor set at 30 deg.do not know if it to high or to low. Live in maryland.
Old 02-07-2010, 06:12 PM   #4
An old Tradesmen
Ok. Now if you posted the indoor coil info that would help.
But, if its 30 outside, and its 70 inside. maybe 90 to 94 depending on CFM through the coil.
Old 02-07-2010, 10:56 PM   #5
walt1122
Rewards Points: 334
Running on only heat pump no aux (elec, gas, etc.) and 30F outside temp out of register will be a blistering 95F if you are lucky!. The one we had in new jersey a few years ago would give 82-85F at those temps. remember it is taking what heat is outside ( heat is anything warmer than the refrigerant in your Heat Pump can transfer from outside to inside your house). In winter it takes a long time to accompligh this. A Heat Pump will naturally run a long time in witer. Only when it can't keep up will it finally bring in the aux heat to maintain the temp. Let it run, let it reach top efficiency and as long as you are "comfortable" you can save money. Don't play with the thermostat. Set it and forget it. Or be very deliberate when you do change the settings. NEVER ever go more than 2 higher at a time if you want to bring up the houses temperature. Otherwise you will turn on the electric coils or the gas( Exception to all this is if you have a hybrid system and have very cheap Natural Gas available, cheap propane around or electric is cheap. Probably not gunna happen so put on a sweater and don't sit close to the register and remeber you are saving money and the world by conserving.
Walt
walt1122 is offline   Reply With Quote
Old 02-07-2010, 11:45 PM   #6
An old Tradesmen
Walt
That unit will do 90 to 94 at 30 outside, if the indoor is 70.
That is a good performing heat pump. The one you had in NJ probably wasn't a 14 SEER.
Old 02-08-2010, 10:42 AM   #7
walt1122
Rewards Points: 334
yeah, that one was a few years old as I mentioned so it probably was more like a 10 or so SEER ( changed out the first one in the late 1980's. so this replacement R-22 was built about that time) Heck our first one that we bought was back in 1976 used R-12 yes R-12 just like the old car air conditioners. Name brand state of the art for the time, a Carrier. Just goes to show how much the technology has advanced. So yes today a temp of 95 at the register from outside temperature at 30F and indoor temp of 70 to me is a "blistering" number if you consider what older units put out. I wasn't critizing just letting the poster know that he shouldn't expect it to perform like a conventional fossel fuel furnace that belches out 110F+ from the registers. Heap Pumps are a great way to heat and cool. just have to understand that they are a "little" different in their performance.
Walt
Old 02-08-2010, 06:20 PM   #8
thanks for info. Like said frist time heat pump owner. expected higher temp .So at 30 degrees outside its going to work alot.I do not know if it better to just burn gas or electric.Seems to defrost a lot? Tnen throws over to gas.Spend to much time listening to heap pump. And listen to fan ram up and down.
Old 02-08-2010, 06:37 PM   #9
An old Tradesmen
Post your electric and gas rate. Delivered all taxes and fee's included.
I can probably tell you your economical balance point then.
Old 02-08-2010, 08:09 PM   #10
Its new house 1650 sf insulation is r32 ceiling and floors. r20 in walls 2/6 walls.
Old 02-09-2010, 12:55 AM   #11
An old Tradesmen
Doesn't tell me what your electric or gas rate is.
infinity heat pump always on aux heat below 40 degree hirrlinger HVAC 4 07-18-2010 12:51 PM
Brand new Carrier Infinity 16 Heat Pump Stopped Working I think needmyac HVAC 3 07-07-2009 06:12 PM
Heat pump problem, indoor fan blows in heat but not A/C or "on" lngroller HVAC 2 06-03-2009 07:55 AM
Ductless Heat Pump for Garage?? brittlediabetic HVAC 25 04-23-2009 02:28 PM
Electric Heat pump in New England? jzinckgra HVAC 7 05-22-2008 02:02 PM
