-   -   heat pump (http://www.diychatroom.com/f17/heat-pump-3806/)
dreck 09-05-2006 10:02 PM
heat pump
hello,
I am new to your community. I am looking for some information about heat pump units & the install price.
I am considering buying a house that is missing the AC unit & parts of the heating unit. Someone has stolen the AC unit, parts out of the heating unit, & all the wiring & plumbing.
The house is 1585 sq. ft. with almost 3/4 basement that did not have heat. I am figuring a 3 ton unit will do the job?
I did a quick google search & saw a Goodman 3 ton unit for $1,300.00 - $1,700.00. Depending on the seer. What is the seer? And how important is this? Is Goodman a good heat pump?
Also, if I were to buy a unit what should I look to pay. I realize a lot of things go into the figure, location, house, size, etc. I am just looking for a ruff guess. House is located in Greenville SC if that helps.
If anyone has an opinion or ideas this would be great.
Thanks, Stuart
oddjob 09-10-2006 09:53 PM
SEER is the seasonal energy efficiency rating. Basically if its a 10 SEER it will remove 10 BTU's of heat from an area for every 1 watt of electricity it consumes. Prices vary drastically from one part of the country to another. I would suggest you get a load calculation done to tell you exactly what your cooling and heating requirements are instead of guessing the size you need.:whistling2:
dreck 09-11-2006 08:18 PM
Thanks, I will do that.
