Heat Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 02-06-2009, 12:54 PM   #1
Rewards Points: 35
Heat Pump
I have a heat pump for heating my home. I've noticed that when it gets cold outside, 40 degrees F and below, the heat pump runs almost continuously and produces little heat. What is a reasonable outside temperature for my heat pump to produce enough heat for my home without the use of heat strips?
czars is offline   Reply With Quote
Old 02-06-2009, 01:29 PM   #2
JohnH1's Avatar
You would have to calculate the heat loss on the home and compair to the Heat pump ratings. There is no set temp. My home is around 25-30 deg before backup starts kicking in a little.
JohnH1 is offline   Reply With Quote
Old 02-06-2009, 04:07 PM   #3
An old Tradesmen
Rewards Points: 6,582
Varies with the home and heat pump.
Some 40, others 20.
Old 02-06-2009, 09:49 PM   #4
Rewards Points: 502
Mine is around 22-25F outside before it just cannot keep up anymore and then the $$$$ backup electric heat kicks in.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 04:05 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 11:28 AM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 03:11 PM
