-   -   Heat Pump (http://www.diychatroom.com/f17/heat-pump-37751/)
czars 02-06-2009 11:54 AM
Heat Pump
I have a heat pump for heating my home. I've noticed that when it gets cold outside, 40 degrees F and below, the heat pump runs almost continuously and produces little heat. What is a reasonable outside temperature for my heat pump to produce enough heat for my home without the use of heat strips?
JohnH1 02-06-2009 12:29 PM
You would have to calculate the heat loss on the home and compair to the Heat pump ratings. There is no set temp. My home is around 25-30 deg before backup starts kicking in a little.
beenthere 02-06-2009 03:07 PM
Varies with the home and heat pump.
Some 40, others 20.
AndrewF 02-06-2009 08:49 PM
Mine is around 22-25F outside before it just cannot keep up anymore and then the $$$$ backup electric heat kicks in.
