Heat Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 09-21-2013, 05:58 PM   #1
Heat Pump
Hey Guys
I was curious, how hard is it to install a heat pump. I'm in no hurry at this point just researching it at this point. Is this a DIY ? I'm pretty inclined.
GRed is offline   Reply With Quote
Old 09-21-2013, 06:10 PM   #2
I really like to DIY when I can, but I believe this is not a DIY job.
Not only is there a lot of knowledge required, there's also a lot of expensive equipment you'd have to purchase.
On top of that: my understanding is that the quality of the installation is more important than the name on the unit.
Plus you'd probably end up in a situation with no warranty.
Sometimes, it pays to have a pro. This is one of those times. IMHO
RoyalAcresRod is offline   Reply With Quote
Old 09-21-2013, 06:11 PM   #3
I appreciate it.. I would suppose that applies to Geothermal as well
Old 09-21-2013, 06:15 PM   #4
I would suspect even more so, especially if you're doing a vertical "well" drilling installation
Old 09-21-2013, 06:23 PM   #5
So how much something like this would cost?
Old 09-21-2013, 06:48 PM   #6
I'm Your Huckleberry
Rewards Points: 2,270
vacuum pump costs about $350.00 cheapest, torch set (oxygen/acetylene) about $350 average including bottles (empty, though, about $15-$20 per bottle fill) plus minimum 5% sodder @ $60.00, nitrogen and then last but not least refrigerant, $400.00 a jug. Let's not forget copper and all hand tools such as tubing cutters to do the job. Cuple of hundred total, rolls of 50' each line. they don't sell partial rolls.
Heat pump size would be detrimental to an hvac contractor's installed and warrantied price.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 09-22-2013, 08:59 AM   #7
Rewards Points: 314
unless its a package unit... then it is get a stand built, an interface duct and a crane.
I would suggest that rather then DIY, become educated on the science of HVAC (google is your friend!!!!). Learn up on manual j, manual d, building envelope science and be an informed consumer!!!!!!!!!
With a good design, good installation and good preventive maintenance almost any HVAC system can last 20 years or more. If the above is done poorly, 7 to 10 year life can be expected, as well as high monthly bills.
bottom line is that initial installation takes tools, skills and lots of education. regular maint is easy after that!!!!!!
bobinphx is offline   Reply With Quote
Old 09-22-2013, 01:37 PM   #8
An old Tradesmen
Rewards Points: 6,886
Install, or swap out?
Lennox Heat Pump no_limit_larry HVAC 4 11-05-2012 05:18 PM
dual fuel heat pump - no heat without propane sweetfarm HVAC 3 10-11-2012 08:07 AM
Can I connect Honeywell Vision PRO 8000 (1 Heat/ 1 cool) to a Heat Pump w/aux for heat coils? TimDavis HVAC 12 01-18-2012 07:06 AM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 08:13 PM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
