I have a two yr. old Goodman heat pump with electric back up that I have had nothing but problems with. This time it will frost up at 30 degrees and will not go into the defrost mode. We put in a new board and temp sensor and still no luck. It has a ten yr. labor & material warranty, but this doesn't help my electric bill when the furnace runs constantly on system + 2. Also the heat pump is still running at this temp. I guess the next step is that he will check the gas when the it hits 50 today. Any suggestions?
It's frustrating because I replaced a 20 yr. old Trane that had no problems for this high efficient heat pump/furnace.
Thanks,
Denpal
Thanks,
Denpal
