Heat Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 03-25-2012, 09:26 PM   #1
heat pump
can you show me how to install a heat pump step by step
mjworks86 is offline   Reply With Quote
Old 03-25-2012, 09:29 PM   #2
i understannd the danger now can you help me do the job
Old 03-25-2012, 09:31 PM   #3
iv dont things like this be fore but cant remember everything and need a refresher where the reply?
Old 03-25-2012, 10:29 PM   #4
sktn77a's Avatar
Rewards Points: 392
If you have to ask how, you shouldn't be doing this. Heat pumps have high voltages and high pressures that require specialized equipment and training.
sktn77a is offline   Reply With Quote
Old 03-26-2012, 04:13 AM   #5
An old Tradesmen
Rewards Points: 7,332
It often takes more then 5 minutes to get an answer.
Old 03-26-2012, 07:10 AM   #6
Rewards Points: 1,216
A heat pump is a very complex piece of expensive equipment that takes many years of schooling to install properly. On the other hand a simple air conditioning system a layman might get away with it with the right help.
Don't do it, you don't want years of weather with a piece of expensive equipment breaking, not holding set point, cool and clammy in the house, running too much or less, etc etc etc.
COLDIRON is offline   Reply With Quote
Can I connect Honeywell Vision PRO 8000 (1 Heat/ 1 cool) to a Heat Pump w/aux for heat coils? TimDavis HVAC 12 01-18-2012 07:06 AM
New Heat Pump Problems Cooling Zombify HVAC 2 04-06-2010 03:42 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 08:13 PM
New Install - Heat Pump Woes... mark1210 HVAC 7 03-07-2010 09:14 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
