Heat Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 02-25-2012, 07:59 PM   #1
Rewards Points: 268
heat pump
This is my first winter with a heat pump. Has no problem keeping the house at 70*F when its 13* outside without backup. Question is, will it cool in the summer heat, as well as it heats in the winter ??
JackDidley is offline   Reply With Quote
Old 02-25-2012, 08:20 PM   #2
sktn77a's Avatar
Rewards Points: 392
Don't see why not. Won't know until the summer!
sktn77a is offline   Reply With Quote
Old 02-26-2012, 03:57 AM   #3
An old Tradesmen
Rewards Points: 8,228
As above, it should. But only time will tell for sure.
Old 02-26-2012, 07:25 AM   #4
at 13* u say? Fahrenheit or Celsius?
hvac5646 is offline   Reply With Quote
Old 02-26-2012, 09:36 AM   #5
Being that he said 70 degrees inside temp, common sense dictates he is using fahrenheit. Unless he is heating his house to over 150 degrees F inside.
mpnret is offline   Reply With Quote
Old 02-26-2012, 09:42 AM   #6
Rewards Points: 1,192
If you have a 13 seer heat pump with 410a gas ,you'll be happy.
bobelectric is offline   Reply With Quote
Old 02-26-2012, 10:08 AM   #7
Check the COP of a heat pump at 13*f and then tell me that.
Old 02-26-2012, 10:50 AM   #8
Rewards Points: 268
Yes 13 SEER with 410a.
Yes I am talking degrees F.
Thanks guys.
Old 02-26-2012, 10:52 AM   #9
Newer cold weather heat pumps can handle it without backup coming on. Or do you really think he is heating his house to over 150 degrees F.
Old 02-26-2012, 03:38 PM   #10
Rewards Points: 268
I will add, the cost seems a little higher than gas. We have had very few days below 20* F this winter, so its not been a big deal. Next winter I expect to program the thermostat to switch to gas a bit sooner. I intentionally let the heat pump run at cooler temps just to see if it would keep up.
Can I connect Honeywell Vision PRO 8000 (1 Heat/ 1 cool) to a Heat Pump w/aux for heat coils? TimDavis HVAC 12 01-18-2012 07:06 AM
New Heat Pump Problems Cooling Zombify HVAC 2 04-06-2010 03:42 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 08:13 PM
New Install - Heat Pump Woes... mark1210 HVAC 7 03-07-2010 09:14 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
