Heat Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 10-13-2011, 09:11 AM   #1
heat pump
Can I put a new 13 Seer heat pump with a 14 yr old air handler
annejones is offline   Reply With Quote
Old 10-13-2011, 09:31 AM   #2
Rewards Points: 154
heat pump
You can put a r-22 heat pump with one but why would you? The r-22 dry ship unit are more expensive and then you have the cost of refrigerant. The AHU is a pretty inexpensive part considering you will get the full manufacturer warranty with the AHU and not with just the outdoor.
Patrick Eubanks is offline   Reply With Quote
Old 10-13-2011, 06:15 PM   #3
heat pump
Some people do but it's a terrible idea. Heat pumps are pretty touchy about having the correct coil. Not only that but you'll have a 1 year warranty instead of 10.
Using Gas heat during Defrost mgroves HVAC 15 12-18-2010 06:51 PM
New Heat Pump Problems Cooling Zombify HVAC 2 04-06-2010 04:42 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 09:13 PM
New Install - Heat Pump Woes... mark1210 HVAC 7 03-07-2010 10:14 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 09:34 PM
