Heat Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 09-16-2011, 08:15 PM   #1
Rewards Points: 268
Heat pump
Almost new Rheem PNL 024 JEZ heat pump quit working. Not getting 24 volts at the thermostat. Cant get 24 V anywhere on the control board, have 240/120 going in. Low voltage fuse is good but there is no voltage getting to it. Is the circuit board dead ?
JackDidley is offline   Reply With Quote
Old 09-16-2011, 08:21 PM   #2
JJboy's Avatar
Check 24vac at the transformer
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 09-16-2011, 08:39 PM   #3
Rewards Points: 268
I dont see a typical transformer. It has a defrost board on top of a control board, a defrost relay, fan relay and two capacitors. There is a blue box mounted to the control board with two large gauge high voltage wires going in it. Maybe an electronic transformer ??
Old 09-16-2011, 08:42 PM   #4
JJboy's Avatar
did you check at the air handler?
Old 09-16-2011, 08:47 PM   #5
Rewards Points: 268
The air handler is actually a gas furnace. It has its own transformer and the furnace is working fine.
Old 09-16-2011, 09:00 PM   #6
JJboy's Avatar
Can you post pictures? The transformer is the only device that step up/down voltage. You should see a transformer in the controller board or outside
Old 09-16-2011, 09:04 PM   #7
JJboy's Avatar
http://www.rheem.com/product.aspx?id...C-713B7A0E4011
Old 09-16-2011, 09:10 PM   #8
Rewards Points: 268
I will get pics in the morning, its dark outside here now. Thanks for the link, thats the unit.
Old 09-16-2011, 09:13 PM   #9
JJboy's Avatar
Let us know the number showing in the controller board display.
Old 09-16-2011, 09:24 PM   #10
Rewards Points: 268
No number. Its like there is no power anywhere on the board.
Old 09-16-2011, 09:31 PM   #11
JJboy's Avatar
Check this video. You need to measure the incoming voltage in the board
http://www.youtube.com/user/dizzieda.../2/ephQCo8ikms
Old 09-16-2011, 09:42 PM   #12
Rewards Points: 268
Thats almost identical. I do have 240 going in. The capacitors have power to all points. I "think" the blue box on the board is the transformer. It has power going in. No way to check output without removing the board. If I do that and there is no power coming out, can that be fixed or do I get another board ?
Old 09-16-2011, 10:05 PM   #13
3 ton heat pump
install a new 3ton compressor and the breaker still trippin some one help with this one please
Dongoddy is offline   Reply With Quote
Old 09-23-2011, 10:02 PM   #14
Rewards Points: 268
Thought I'd update this. The guy came out today. It was the thermostat that was causing the problem. I was expecting him to hit me with a big bill but he would not accepy any $$$.
Using Gas heat during Defrost mgroves HVAC 15 12-18-2010 06:51 PM
New Heat Pump Problems Cooling Zombify HVAC 2 04-06-2010 04:42 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 09:13 PM
New Install - Heat Pump Woes... mark1210 HVAC 7 03-07-2010 10:14 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 09:34 PM
