Heat Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 04-29-2011, 09:25 PM   #1
heat pump
if it is 40 degrees outside how can a heat pump heat a building
lornes is offline   Reply With Quote
Old 04-30-2011, 04:03 PM   #2
An old Tradesmen
Rewards Points: 6,846
By absorbing the heat that is the air. There is always heat in the air. If there wasn't, then it would be absolute zero outside, and the air would be a solid block of frozen oxygen, nitrogen, argon, and a few other misc compounds.
Along with the heat of compression.
Using Gas heat during Defrost mgroves HVAC 15 12-18-2010 05:51 PM
New Heat Pump Problems Cooling Zombify HVAC 2 04-06-2010 03:42 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 08:13 PM
New Install - Heat Pump Woes... mark1210 HVAC 7 03-07-2010 09:14 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
