HEAT: Plenty Of Airflow But, Little Heat To Some Rooms - HVAC - DIY Chatroom Home Improvement Forum
Old 11-24-2012, 12:32 PM   #1
Rewards Points: 16
Question
HEAT: Plenty of airflow but, little heat to some rooms
Hello all,
AirHandler: ARUF486016*
# of Runs: 7
Duct Size: 10 inch rounds
I seem to be having load balancing issues. Two of the longest runs are on the right side of the plenum right next to each other. I have dampeners installed in most of them and if I shut down most of the ducts except those two the first of the two runs seems to get all the heat while the second of the two longer runs gets amazing airflow but, little to no heat.
My assumption that having those two runs on the same side of the plenum mixed with having those runs be 10 inch rounds is probably causing my issue. Does this sound possible?
Run 1 is about 40 feet in length and splitting 3 times at the very end feeding a 12x14 room and then following the room a bathroom/closet.
Run 2 is about 30-35 feet splitting once and is heating two 10x12 rooms.
Thanks,
Randy
tathamr is offline   Reply With Quote
Old 11-24-2012, 01:34 PM   #2
An old Tradesmen
Rewards Points: 6,498
Move them further back on the plenum. They are probably to close to the front where the strip heater is not putting off much heat.
Old 11-24-2012, 01:47 PM   #3
Rewards Points: 16
Just to clarify further back you mean towards the end of the plenum and further away from the airhandler.
Old 11-24-2012, 02:25 PM   #4
I'm Your Huckleberry
Rewards Points: 2,270
Yes, that's what he means, towards the end of the plenum.
Thanks.
Doc Holliday is offline   Reply With Quote
Heat pump is not running on Heat mode frank06 HVAC 17 03-13-2012 04:34 AM
Can I connect Honeywell Vision PRO 8000 (1 Heat/ 1 cool) to a Heat Pump w/aux for heat coils? TimDavis HVAC 12 01-18-2012 08:06 AM
Using Gas heat during Defrost mgroves HVAC 15 12-18-2010 06:51 PM
No Aux heat with American Std HP/Trane AH and Honeywell IAQ FREEZING!!!! JackBP HVAC 3 12-18-2010 03:50 AM
Governments Renewable Heat Incentive SMurray Green Home Improvement 1 10-24-2010 09:30 AM
