Old 01-13-2009, 08:56 PM   #1
Heat pipe in wall banging noises?
Steam heat, why is the pipe going from the basement to the 2nd floor making a banging noise? Never did this before, just started this week.
helpless handyman is offline   Reply With Quote
Old 01-13-2009, 09:00 PM   #2
An old Tradesmen
Water and steam are colliding with each other.
Old 01-13-2009, 09:10 PM   #3
What can be done?
Old 01-13-2009, 09:31 PM   #4
Dr Heat's Avatar
try wrapping the pipe with insulation. The problem is steam is cooling and condecing too soon and draining back.
Dr Heat is offline   Reply With Quote
Old 01-13-2009, 09:52 PM   #5
All pipes in the basement are wrap up with that pipe insulation.
Old 01-13-2009, 09:53 PM   #6
An old Tradesmen
Since it just started happening.
Have you changed anything at all.
Removed insulation from any pipes.
Remodeled the basement. Or changed anything in the basement.
Is it a single or 2 pipe system.
Old 01-14-2009, 07:23 PM   #7
Thanks, the only thing I am renovating the basement and the ceilings are closed now. The main 2 inc pipe is insulated, only one pipe is doing the knocking, I am going to see which radiator it feeds and make sure the radiator is on a slant towards the pipe. It's a one pipe system.
Old 01-14-2009, 07:32 PM   #8
An old Tradesmen
Are you sure, you didn't accidentally raise a pipe while if you redid the ceiling.
Check your air vents.
Also, hopefully, you didn't enclose a main vent.
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 11:24 AM
Minimum wall thickness for electrical dc4nomore Electrical 10 10-10-2008 09:00 PM
Building a soffit around a drainage pipe along the wall ssudha17 Building & Construction 12 10-04-2008 04:18 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
