-   -   Heat pipe in wall banging noises? (http://www.diychatroom.com/f17/heat-pipe-wall-banging-noises-35848/)
helpless handyman 01-13-2009 08:56 PM
Steam heat, why is the pipe going from the basement to the 2nd floor making a banging noise? Never did this before, just started this week.
beenthere 01-13-2009 09:00 PM
Water and steam are colliding with each other.
helpless handyman 01-13-2009 09:10 PM
What can be done?
Dr Heat 01-13-2009 09:31 PM
try wrapping the pipe with insulation. The problem is steam is cooling and condecing too soon and draining back.
helpless handyman 01-13-2009 09:52 PM
All pipes in the basement are wrap up with that pipe insulation.
beenthere 01-13-2009 09:53 PM
Since it just started happening.
Have you changed anything at all.
Removed insulation from any pipes.
Remodeled the basement. Or changed anything in the basement.
Is it a single or 2 pipe system.
helpless handyman 01-14-2009 07:23 PM
Thanks, the only thing I am renovating the basement and the ceilings are closed now. The main 2 inc pipe is insulated, only one pipe is doing the knocking, I am going to see which radiator it feeds and make sure the radiator is on a slant towards the pipe. It's a one pipe system.
beenthere 01-14-2009 07:32 PM
Are you sure, you didn't accidentally raise a pipe while if you redid the ceiling.
Check your air vents.
Also, hopefully, you didn't enclose a main vent.
