Hello all:
Iam having a problem with a Magic-Pack unit. I had a service technician out and he coudn't fix it. I'll try to describe the problem as best I can.
Heat was working with no problem. Now it very rarely comes on, but occasionally does work for a short period of time and then it shuts down. I have turned on/off the emergency reset switch, changed the batteries in the thermostat, turned off the thermostat,raised the thermostat to a high set point.
In all cases either nothing happens, or the blower runs for a short period, the gas burner might fire, but then it shuts down. There is clicking out at the unit as it seems to be trying to start up. I just tried setting the fan to run constantly and nothing happened. The unit was installed in March of 2009. 48000 BTU, Honeywell electronic thermostat.
I'm thinking of replacing the thermostat, least costly option, since it cost me $110 for a technician to change the batteries in the thermostat. They were my batteries. Any help would be appreciated.
Thanks,
Thanks,
