Old 12-04-2012, 08:01 PM   #1
Heat not blowing to 2nd fl bedrooms
I live in a two-story single family and I've got a brand new furance and also ducts recently cleaned. I just cant figure out why sufficant heat is not blowing through the 2nd story floor vents. PLEASE HELP
newwifeey1 is offline   Reply With Quote
Old 12-04-2012, 08:03 PM   #2
bbo
maybe one of the dampers got flipped?
bbo is offline   Reply With Quote
Old 12-04-2012, 09:31 PM   #3
JJboy's Avatar
Check the temp in all registers in cooling and heating. The temp difference should be small
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 12-04-2012, 09:52 PM   #4
concretemasonry's Avatar
Also, make sure you have adequate return air vents. If the old air is not drawn out, the new air will not get there is any qualtity.
Dick
concretemasonry is offline   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
JJboy (12-04-2012)
Old 12-04-2012, 10:26 PM   #5
Missouri Bound's Avatar
Is it safe to assume that the old system worked properly? Is the new unit smaller than the old? Any other changes? I too would look for a closed damper. Have you gotten any help from the installer yet?
Do you want it your way or the right way?
Old 12-04-2012, 11:43 PM   #6
try running the circulating fan on constant low or medium speed..you may have to call the installer back to set up the thermostat/controls to do this..
techpappy is offline   Reply With Quote
Heat pump is not running on Heat mode frank06 HVAC 17 03-13-2012 04:34 AM
Heat Pump Not Blowing Cold RB101011 HVAC 18 09-29-2011 11:03 PM
Prestige Boiler keeps blowing a fuse, no heat for days!! ryan04 HVAC 13 09-25-2010 07:18 PM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 07:15 AM
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
